Suppress a part using the variable table using Solid Edge ST4
I have a seat valve with a nose diameter of 6" and nose depth of 1/4". I want to create a formuala in the variable table that states if there is no nose diameter then suppress the nose diameter and depth on the part. Currently on my design I created a cutout command for the nose diameter and depth hoping that will help but I don't know if it's possible.
RE: Suppress a part using the variable table using Solid Edge ST4
Here´s a video
And I can share You the Solid Edge part if you want to download and give it a try (Solid Edge)
