thread483-198846 - The Calculation of Viscosity Blending Indices Using the Refutas Equation
Here we use the following equation to find the percentage of the mixture Marine Fuel (let's call mf380) as well as the Marine Gas Oil (MGO we call mgo) that when making the mixture becomes a Marine Fuel 150 cSt 50 ° C (let's call mf150), for example.
It turns out that the formula used establishes that the products are the same temperature, but by the company's internal regulatory matters calculations are as follows when we make a mixture using the following products:
Marine Fuel MF380 = 380 cSt at 50 ° C and
MgO = Marine Gas Oil, usually 3 to 5 cSt at 40 ° C.
v, mf180 = 150 cSt at 50 ° C
v, M380 = 380 cSt at 50 ° C
v, MgO = 4 cSt at 40 ° C
a, mf380 = (1 + 1 / v, mf380) ^ (v, mf380) = (1 + 1/380) ^ (380) = 2.714713748
a, MgO = (1 + 1 / v, MgO) ^ (v, MgO) = (1 + 1/4) ^ (4) = 2.44140625
a, mf150 = (1 + 1 / v, mf150) ^ (v, mf150) = (1 + 1/150) ^ (150) = 2.709275911
b = ln the mf380, mf380 = ln = 2.714713748 0.996681408
b = ln the MgO, MgO = ln = 2.44140625 0.892574205
b = ln the mf150, mf150 = ln = 2.709275911 0.996681408
The formula employed, who do not know the name, is as follows:
A = 3.82227;
B = 79.20991;
w, w + mf380, MgO = 1
w, MgO = 1 - w, mf380
IMI = A * ln (ln (vi + ai - bi)) + B
IM m150 = 3.82227 * ln (ln (150 + a, mf150 - b mf150)) + 79.20991
IM m150 = 3.82227 * ln (ln (150 + 2.709275911-.996681408)) + 79.20991
IM, m150 = 85.37838814
IM M380 = 3.82227 * ln (ln (380 + 2.714713748 to 0.996681408)) + 79.20991
IM, M380 = 86.02309508
IM MgO = 3.82227 * ln (ln (4 + 2.44140625 to .892574205)) + 79.20991
IM MgO = 81.26854298
IM mf150 = w * IM mf380, mf380 + (1 - w mf380) * IM MgO
85.37838814 = w, mf380 + 86.02309508 * (1 - w, mf380) * 81.26854298
w = 0.8644021716 mf380
w, MgO = 0.355978284
Thus, the percentage of MF380 is 0.8644021716.
The MgO is 0.355978284.
The great problem, as seen, it is not always feasible to make conversion of MGO 4 cSt at 40 ° C to 50 ° C.
So, is there any formula that does not depend on the products are the same temperature? Since it is not feasible to further analysis to convert the MGO 4 cSt at 40 ° C to 50 ° C
RE: thread483-198846 - The Calculation of Viscosity Blending Indices Using the Refutas Equation
Do you really think that the viscosity of a blended mixture could be obtained when the mixing was not even sufficient to reach a uniform temperature!
"People will work for you with blood and sweat and tears if they work for what they believe in......" - Simon Sinek
Mgo = Marine Gas Oil, usually 3 to 5 cSt at 40 ° C.
v,mf180 = 150 cSt at 50 °C
v,mf380 = 380 cSt at 50 °C
v,mgo = 4 cSt at 40 °C
a,mf380 = (1 + 1 / v,mf380) ^ (v,mf380) = (1 + 1/380) ^ (380) = 2.714713748
a,mgo = (1 + 1 / v,mgo) ^ (v,mgo) = (1 + 1/4) ^ (4) = 2.44140625
a,mf150 = (1 + 1 / v,mf150) ^ (v,mf150) = (1 + 1/150) ^ (150) = 2.709275911
b,mf380 = ln (a,mf380) = ln(2.714713748) = 0.996681408
b,mgo = ln (a,mgo) = ln(2.44140625) = 0.892574205
b,mf150 = ln (a,mf150) = ln(2.709275911) = 0.996681408
A = 3.82227;
B = 79.20991;
w,mf380 + w,mgo = 1
w,mgo = 1 - w,mf380
IMi = A * ln (ln (vi + ai - bi)) + B
IM,mf150 = 3.82227 * ln (ln (150 + a,mf150 - b,mf150)) + 79.20991
IM,mf150 = 3.82227 * ln (ln (150 + 2.709275911-0.996681408)) + 79.20991
IM,mf150 = 85.37838814
IM,mf380 = 3.82227 * ln (ln (380 + a,mf380 - b,mf380)) + 79.20991
IM,mf380 = 3.82227 * ln (ln (380 + 2.714713748 - 0.996681408)) + 79.20991
IM,mf380 = 86.02309508
IM,mgo = 3.82227 * ln (ln (4 + 2.44140625 - 0.892574205)) + 79.20991
IM,mgo = 81.26854298
IM,mf150 = w,mf380 * IM,mf380 + (1 - w,mf380) * IM,mgo
85.37838814 = w,mf380 * 86.02309508 * (1 - w,mf380) * 81.26854298
w,mf380 = 0.8644021716
w,mgo = 0.355978284
The MGO is 0.355978284.
The great problem, as seen, it is not always feasible to make conversion of MGO 4 cSt at 40 °C to 50 °C.
to convert the MGO 4 cSt at 40 °C to 50 °C
But what is the name of the formula used? I knew that would be the same temperartura, but there would be another set of formulas or a computational method that calculates the percentage having as entries mixing products with different temperatures?
For example, the program BCALC.EXE (BunkerCalc Shell for Windows V1.0), Module "Blending Ratios" calculates the percentage of mixture using different temperatures.
But to do so must have some algorithm that converts the temperature of products (Residual Fuel and Fuel Diluent) to the target temperature of the mixture. Certainly must have the constants A and B determined already in formula:
log10 (log10 (v + 0.7)) = A - B * log10 (T + 273.15)
v = viscosity in cSt
t = temperature in ° C
log10 = logarithm to the base 10
But as I said, that is not feasible in every mix I have to calculate a viscosity at two different temperatures ever. It would be practical, even with some loss of accuracy, using values ​​of A and B tabulated for both Residual Fuel well as for Fuel Diluent.
I look forward, if possible, help!
Since now, thank you all!
I think that may be the Huang-Johnson relationship.
