Project curve in an assembly draft, NX7.5.
Drafting an assembly in 7.5, the Project curve no longer works. I can’t pick on any of the splines or curved edges. It works in a part but not in an assembly. It worked fine in NX5 part and assembly. I do have the sketch active in the view I am working on. Am I missing something? I need to use this to create hatched areas.
RE: Project curve in an assembly draft, NX7.5.
www.nxjournaling.com
In the View Style
In the General tab, towards the bottom, change the extracted views from none to associative
