modeling through bolts in SAP 2000
Hi all,
To repair the bottom chord of a wood roof truss, we are looking sistering a portion of it (8 ft. on either side of king post, the total length between panel points is about 36 ft.) by attaching channels on the sides via through bolts. My question is, how do I model the connection between the existing wood chord and the new channels on the side?
Thanks in advance for any comments and suggestions.
RE: modeling through bolts in SAP 2000
The assumption that no sliding occurs should be validated by calculating the longitudinal shear on the bolts and checking that it can be carried safely.
Regards.
Analysis and Design of arbitrary cross sections
Reinforcement design to all major codes
Moment Curvature analysis
http://www.engissol.com/cross-section-analysis-des...
