section along an edge of a cylinder
NX 7.5
This is an error that I have run into just about as long as I've been running UG. if I cut a section that is offset from the centerline of a cylinder at same distance of the radius of said cylander I get a section error.
for example:
View name: SX@94
View type: Section view
Error: Modeler error: modeler error: please report fault
I assume this is because it is trying to compute a section with a non-existant width. I know various work arounds from slightly offsetting the section to moving the cylinder a negligibe distance so it is off the section plane. What I want to know is if this is something that will be or has been fixed in future releases?
for example:
View name: SX@94
RE: section along an edge of a cylinder
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
