Stainless pipework left for years
Hi if stainless steel pipework was installed, welded and NDT was carried out. Would it be ok to leave it for 5 years before use? If not why not?
RE: Stainless pipework left for years
Clean? Dry? Dehumidified? Isolated from bugs, critters, debris, shock, corrosion/electro-galvanic problems? Covered completely or buried or in mid-air?
Power plants have been left in-place for years as construction proceeded elsewhere or projects were delayed/defunded. Ships have been left dehumidified and moth-balled for years before re-use. Others have rusted out and become useless in just a short time.
But re-use repair and cleaning and the initial preservation HAVE to be very good.
It would be great if you could remove internal moisture, and seal it up with a nitrogen blanket.
The main threat to SS systems is chlorides. Pools of water somehow collect salts and can discolor ar sometimes eat through SS.
An external painting system should be considered for long term layup.....
Is it coated, buried, bare, exposed to salt water, CP protected?
"People will work for you with blood and sweat and tears if they work for what they believe in......" - Simon Sinek
Thank you for the reply. It is basically just going to be sat on concrete not covered. The only work going on around it would be electrical work.
Why would you purposefully purchase, fabricate and install a piping system five years early ??
I still maintain that a 5 psig nitrogen blanket would be a good investment.....
Because if we dont we would have to chop the 8 tonne tanks in half to install them. Either that or do a verticle lift. I would personally go for a verticle lift through some penetrations in the levels but some people have deamed it as unsafe. So a nitrogen blanket inside and maybe wrap the outside in some nice wax wrap or denso tape?
Denso....Now there's a bell from the past. We used to wrap whole plants in it! Great for sealing low pressure leaks too! Did not know you could still get the stuff!!!
