RISA locked joint problem
I have a model that I am working on for a flat roof building. I know it may not sound good, but I used the flat roof to ease my calculation checks. I have added the sub mesh on the metal plate as recommended in an earlier post. However, now I am getting a lot of locked joints. Can anyone explain to me how to unlock these? Also, in the Load Combinations, is the Dead load the only Y value that receives a -1? The model is attached.
www.gulfcoastinfrastructure.com
RE: RISA locked joint problem
Personally, I would change the member end relases for the internal truss members to fixed-fixed. After all, it really is one piece of wood, isn't it? If not, then it needs to be braced in the Z direction in some way or it will be unstable.
On another note, the bases of your columns are set using the "Fixed" boundary condition code. You may want to change this to the "reaction" boundary condition code. The effect on the model is essentially the same. But, the "fixed" boundary condition code asks the program to suppress the calculation of joint reactions. So, you will not be able to see how much force goes into your base plates.
