grinding
grinding
How can I grind economically (a few million pieces) ceramic discs to squares / rectangles? Discs are 8 to 20 mm diameter and 2 to 3 mm thick. Material is sintered BaTiO3 , ceramic capacitor. I don't want to use adhesives, just mechanical clamping.
Thanks.
Thanks.
RE: grinding
RE: grinding
Tom
RE: grinding
RE: grinding
Abrasive,
I imagine a ceramic rectangle of 8 x 5 mm coming out of a disc of 8 mm. This disc is grinded on two sides only. In this way I have a ceramic with 2 rounded sides and 2 straight sides
Surface finish of grinded sides Ra about 5 to 10 ยต is OK, not very critical. Parallellism about 0.2 mm for the entire length of 6.2 mm. Quantities a few million pieces per year.
I'm thinking of something as centerless grinding, feeded in continu.
Tomwalz, what is EDM?
Jos
RE: grinding
RE: grinding
Sawing is also a possibility. But also here I don't want to use adhesives.
I'm interested in autoloading fixtures for grinding and also the appropiate grinding machine.
RE: grinding
RE: grinding
See the March 2002 IDR (Industrial Diamond Review) for an article on grinding ceramics.
tom
RE: grinding
I'm not in the possibility to get the article in an easy way. Is it worth the effort? What I'm looking for is a DOUBLE HEAD SURFACE GRINDER WITH AUTOMATIC THRU-FEED WITHOUT USING WAXES OR ADHESIVES.
Parts are discs, put on their round side and grind down to become near-rectangles, by grinding upper and lower part.
If this magazine writes about this subject I'll do much effort to get it.
To my knowledge EDM is a slow process which has benefit for some typical situations (very hard materials) which cannot be resolved by other means. Isn't it?
Thanks anyway.
RE: grinding
Industrial Diamond Review is:
http://www.idrmag.com/
You want March 2002 and I think it is called EDC grinding
The following have some really good new technology for grinding ceramics.
Agathon Switzerland New grinder technology
AGIE Charmilles Group EDM technology
Al Bouchard Multi pass technology
Blaser Swisslube, Inc. Coolants
Diametal Wheels
GE Superabrasives Wheel design
Keep me in mind if you want to braze ceramics.
tom
RE: grinding
RE: grinding
You appear to be talking about a Double Disk Grinding machine with some type of Ferris Wheel or Elevator type of loading fixture to securely hold groups of parts as they pass between the Wheels. This would require rather large diameter wheels and would be great for automating the operation.
The Thrufeed System as applied to double disk grinding, which you mentioned earlier as a take-off of O.D. Thrufeed Centerless Grinding, would be difficult to implement due to the tendency of the parts to rotate as well as tip unless you kept heavy continuous pressure on the in-going parts as well as the out-going ground pieces. IMHO, This would be a high scrap process.
Another option, for smaller production quantities, would be to clamp a stack of the pieces in a ratchet type fixture which allows the two opposing sides to be simultaneously ground on a Straddle Grinder. The Stack of parts would then need to be indexed 90 degrees with the Ratchet mechanism to grind the other 2 opposing sides. The Tolerences required would dictate the design of the fixture. Having extra Fixtures would allow the parts to be pre-loaded into the fixtures so that down-time would be minimized. Advantage would be smaller diameter wheels and lower cost machines and fixturing.
If you decide to perform either of these operations and are wanting to do large quantities, Structured Porosity Vitrified Bond Diamond Wheels would be very effective for this type of operation and cut your wheel maintanance, trueing, dressing costs.
Hope this helps.
RamingtonStall
