Max thickness / high pressure
Is there as per ASME VIII div 1, any relationship between the maximal thickness of metal sheets for a pressurized vessel and its diameter. I need to make the design of a CS drum of 387.9 bar g / 93.3°C design conditions. Diameter is 1625 mm / height = 3000 mm TL to TL
The thickness is expected to be very high. Is there a maximal thickness for the shhet of metal used to built this vessel or do I need forged material ?
RE: Max thickness / high pressure
You are out of the scope of Section VIII Div.1, see U-1(d) pressures exceeding 3000 PSI. So try Div. 2. Still it is possible to keep your vessel in Div. 1 but you need to preform some additional calculations at the satisfactory of your AI.
Good Luck,
Gert
However check the new Div.3 of ASME VIII for high pressure vessels.
prex
http://www.xcalcs.com
Online tools for structural design
The information you get from Section 8, div 1 will just tell you how thick of a wall you need. I don't have any knowledge of Division 1, but I know for Division 3 the materials I can select from are limited. We are making a vessel right now with a 14" wall thickness. I may be able to find a 14" thick plate, but if Section 2 says that for this material I am only allowed to have it 2" thick then I must look for a new material.
Specifically for Division 3 all of my vessels are forged using SA-723. For nearly 30 years the company has been making vessels out 4340, forged and heat treated, however section 2 only allows 4340 to be used as bolting material.
kyong
I agree with kyong. ASME Sec. VIII Div. 1 can be used for more than 3000 psi. However, Div. 2 is more economic. Please comment.
I think the section VIII rules refer to a different design code or appendix for diameter ratios above some value, perhaps 1.6:1
The wiser method is to use a ribbon wound multi layer pressure vessel, as used in ammonia reforming work overseas. Unlike monolithic vessels, a crack will not propagate to vessel failure in a mulit layed vessel, and the thernal stresses are bounded to lower values. Also, the lead time is MUCH shorter.
