Problem with step file and converting to an allcatpart.
I received a step file of an assembly from an external company. My goal is to create an allcatpart for this assembly however when I try this I get problems when trying to use the boolean assemble command. I want to assemble all the bodies into one body. It works for all the parts except for one. While debugging the part I noticed I was not able to put a "pocket" in this particular part. But for all other bodies I can modify. I talked to the company that provided the orginal step and they said the problem is on my side from step conversion to catpart. I am not sure this is the case. The native software is Solidworks.
Any ideas on how to "fix" the part so it can be assembled into the single body?
RE: Problem with step file and converting to an allcatpart.
Derek
Win XP64
R20/21, 3DVIA Composer 2012, ST R20
Dell T7400 16GB Ram
Quadro FX 4800 - 1.5GB
What results did you receive with GSD intersect solid --> solid. BTW you should do this as a datum item.
Win XP64
Dell T7400 16GB Ram
