Ethyline pipeline operating near triple point
We need to uprate the carrying capacity of an ethylene pipeline 140 kilometer long and 14" diameter. It is proposed to operate the supply side of the pipeline near the triple point of ethylene, MAOP of 52.8 bar absolute at 10°C reducing to 20 bar at the outlet of the pipeline.
There is a concern about possible two phase conditions in the pipeline. The client reports that the ground temperature is 10°C the length of the pipeline. Ethylene flow is currently 42000 Kg/h maximum and the uprated flow will be 81500 Kg/h.
RE: Ethyline pipeline operating near triple point
I would just like to point out that my pressure, temperature and density numbers given above come from ASHRAE’s THPRSI that I have found very reliable.
