ISOLATING JOINT ADDITIONAL PROTECTION
Have you ever seen addtional protection on isolating joint that protect the hub section from sparkling or current leakage?
In a specification used for Isolating Joint there is the following statement:
"An external plastic sheath shall be applied over the external paint coating in the area of the hub in order to provide added protection against sparking and current leakage. The sheath shall extend for a minimum of 200mm to either side of the insulated space between joint sections."
Which type of protection shall be needed? Is it a shrinkable sleeve? Is it an additional coating?
Thanks in advance for your help.
RE: ISOLATING JOINT ADDITIONAL PROTECTION
prognosis: Lead or Lag
