Simple macro to know if a part is visible or not
I am stuck with a macro, I hope you could help me.I am trying to write a short macro to go thru each one of the parts in a product and just let me know if it's visible or not.
Thank you.
Thank you.
RE: Simple macro to know if a part is visible or not
Shouldn't be so complicated, use search function for parts inside assembly, count parts, see if each one of them is visible (or hidden) , if condition is true (or false) then write in a text file part name (or use a message).
Can we see what you've done up to now ? If I remember correctly I've posted a macro which is putting in show all hidden parts and products (but frankly speaking I'm not so sure I really did it
Fernando
https://picasaweb.google.com/102257836106335725208
Option one: Check every parts in the product and report if it's visible or not.
For iProduct = 1 To oParent.Products.Count
Set oChild = oParent.Products.Item(iProduct)
If oChild.Parameters.Count <> 0 Then
If oChild.Parameters.Item(oChild.Parameters.Count).ValueAsString = "true" Then <----Original code which I wanted to change to check the visibility
frmGXCreator.lstParts.AddItem oChild.PartNumber
Set params = oParent.Products.Item(iProduct).Parameters
If oChild.Products.Count = 0 Then
' oChild.PartNumber = oChild.PartNumber & "_" & strAppend
' SaveAsPartNumber oChild.ReferenceProduct
Else
WalkThroughTree oChild.ReferenceProduct
End If
End If
End If
Next
Option two: Search and select only visible parts. The part I cannot do is to check the properties of each one of the selected items.
Dim MySel
Set MySel = CATIA.ActiveDocument.Selection
MySel.Clear
MySel.Search ("'Assembly Design'.Part.Visibility=Visible")
MsgBox MySel.Item(1).Name
For iProduct = 1 To MySel.Count
''Code to check each one of the selected parts
Next iProduct
Sub CATMain()
Dim productDocument1 As Document
Set productDocument1 = CATIA.ActiveDocument
Dim selection1 As Selection
Set selection1 = productDocument1.Selection
selection1.Search "CATAsmSearch.Part.Visibility=Hidden,all"
MsgBox "Number of CATParts in NoShow: " & selection1.count
for k = 1 to selection1.Count
MsgBox "PartName: " & selection1.Item(k).LeafProduct.Name
next
End Sub
Fernando
selection1.Item(k).LeafProduct.saveas("C:\" & k & ".CATPart") <----line added
next
...but it didn't work. Could you help me out once more.
Fernando
-Read the existing files in a folder e.g. GX001.CATPart, GX002.CATPart, etc.
-Create a list of the visible parts in the Product. <---Done with your code, thanks.
-Propose and alternative name for the visible parts with the next sequential GX-number
-Product save as GX003.CATProduct
-Save AS each one of the visible parts in the product as GX004.CATPart, GX005.CATPart, and so on <---this is the next step which I cannot make it work so far.
I have previous experience writing code in VB and VBA but I have recently started with CATIA so I still do not know the objects/methods/properties of CATIA in VBA.
Thank you.
What you want it can be done, but it takes a little time to do it.
Fernando
So far I've been using v5automation.chm as my main source of information.
Thank you
Fernando
