Annealing Aluminium
Annealing Aluminium
Annealing Aluminium
Want to anneal two aluminum samples at home with household equipment as a little experiment. Just wondering what you guys think on the methods. Not sure if I am better off setting the oven to maximum heat or using the fireplace. Just going to quench in water.
RE: Annealing Aluminium
Hmmmn.
What maximum temperature do you think you are going to get from either? (Hint: Test BOTH methods first. MEASURE the entire cross section of your part (make a test piece!) with an IR thermometer to see just how (poorly!) your heat "evenness" is going to be. For your problem you MUST get ALL section of your part up to the required temperature for the required time WITHOUT over-heating the more closely exposed and thinner parts to a too-high heat.) I really, really don't expect any type of even temperature distribution from your fireplace. Even with charcoal piles around the AL part.
2nd. The microwave oven is not recommended. 8<)
My microwave convection oven can only get to 450 F .... not very high. 8<(
3rd. Oxy-acetylene burners with a rosette tip "might" work if you can submerge the part in a heat-transferring uniform rock or gravel or SSTL pebble-type mixture that evens out the heat flux over the whole part.
