cooling process of thermoplastics
Hello everyone,
I am trying to simulate the cooling process of thermoplatics in abaqus.
I am getting the results with shell elements but when i am using solid composite elements, it gives an error stating 'LAYERED MATERIAL PROPERTIES CANNOT BE USED WITH THESE ELEMENT TYPE'.
Also, I have read, i cannot use solid composite in abaqus...
If anyone can help me out or suggest something..
Thanking you...
jwalant86
RE: cooling process of thermoplastics
Hi jwalant86,
Sounds like you are attempting to use a 2D solid element which indeed does not support layered material properties. You must use 3D solid elements in order to use layered material properties.
Firehole Composites
www.firehole.com
