Groove in Drywall
Groove in Drywall
I'm trying to route a small wire thru the house and was considering how I could conceal it (home entertainment/not power). A thought I had was to use a router or other tool to run a shallow groove in the ceiling adjacent to molding or ceiling/wall intersect. I'd then mud the wire into the groove and touchup paint. Is this a totally stupid idea? Am I going to kill the structural integrity of the drywall? Would it depend on whether I'm running parallel vs perpendicular to ceiling joists?
RE: Groove in Drywall
B.E.
The good engineer does not need to memorize every formula; he just needs to know where he can find them when he needs them. Old professor
I don't think this would even register on a list of structural concerns -- it's not like you are a plumber with a hole saw...
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
Garth Dreger PE - AZ Phoenix area
As EOR's we should take the responsibility to design our structures to support the components we allow in our design per that industry standards.
Mike Halloran
Pembroke Pines, FL, USA
There should be no reason you cannot simply put a pair of holes in the drywall near the top and at the bottom and fish the wire. There may be fireblocking in the wall, about mid-height. Across a ceiling, I'm guessing you don't have an accessible attic space. If you have crown molding, there is probably a gap behind the molding. Drill a pair of holes where you need them, then vacuum a string with a cotton ball tied in the end from one hole to the other (works if the drywall is properly closed.) Pull your wire through with the string. Another thing I have done is to add a small molding to the edge of an existing one. The slight change in profile adds to the look.
