problem with the machine
hello, I have a problem with the machine (AMADA fo 3015) it discharges almost 4 times in 8 hours (etj'obtenu of bad cuts in all the great thickness
Note: I change the bottle yesterday GAS Lasallian 83 ... and it is possible that there's a default at the gas ...
thank you all
thank you all
RE: problem with the machine
Maybe consider which supplier you are using, too.
Jay Maechtlen
http://www.laserpubs.com/techcomm
Check the PSU voltage at base discharge (laser sequence 30), and compare to the values on the Fanuc datasheet.
Do a leak test to make sure that is OK as well.
