DC-DC 50W Isolator (or Transformer )
Hi
I want to design a DC-DC isolator with the following spoiec
Input voltage 24-48V DC
Input Current : 0-2A
Power : Approx 50W
Output voltage : 24-48V
Output Current 0-2A
Output Power :Approx 50W
Efficiency : about 90%
Isolation : Input isolated from Output
Control : No control of the duty Cycle required- Fixed Duty Cycle
Application : This module will be used to isolate the Input DC supply from the Output DC supply . Deos anyone know where I could find a suitable reference design or can suggest a suitable DC-DC converter design i could use ? Basically is it is a 1:1 DC-DC Isolation Transformer .
RE: DC-DC 50W Isolator (or Transformer )
I don't want to regulate the input or output voltage . I want to isolate input voltage only
Output Current 0-2A
That defines regulation; not good regulation, but regulation nonetheless.
TTFN
So do you want it to track the input voltage. A TL494 could drive a couple of fets and a push push pull transformer. Rectify that and sense through an opto isolator. Compare that with a second opto isolator sensing the input voltage. That should track pretty well.
Thanks OperaHouse . Good suggestion !!
Hi OperaHouse
You proposed Push/Pull . Why did you choose push/pull ? Would a Two transistor forward coverter be easier to control and have simpler magnetics ?
Does the push pull have advantages over the forward converter for trhis application ?
Re Push-Pull
Yes it has advantages. Doesn't DC saturate the magnetics for one. Better efficiency, lots of other things going for it, too.
Gunnar Englund
www.gke.org
Dromroe, I agree with skogsgura and operahouse. I did a similar isolated push pull once. 15V to 15V at 30W.
Here's a few tips to make it work:
* turns-ratio slightly higher that 1:1 to make up for the diode drops.
* 50% duty on each half. Use a dual-output switching regulator IC and ramp up the soft start enough to avoid over current at start up, but set the feedback pin low so it goes to full duty.
* small inductor at the center tap to avoid high cross coupling spikes and to keep the currents from being too trapezoidal.
* Do a quick model in spice and you'll see the waveforms of current I'm referring to above.
The power specification has been changed from 50 to 500W. The input of the DC-DC Isolator vvoltage will be from a capacitor bank that will be charged by a current source . The output of the DC-DC Isolator will be connected to a constant voltage load . Therefore we should not to provide closed loop input or output voltage regulation . A converter operating with a fixed duty cycle should be ok . The input to the converter will act like a constant voltage load . The output will be a fixed voltage . The input output voltage ratio will be defibned by the Transformer and the duty cycle 50% . Is a push /pull still the best topology condidering a 500W power level?
"The output will be a fixed voltage . The input output voltage ratio will be defibned by the Transformer and the duty cycle 50% ."
Make up your mind. Either it tracks or the duty cycle varies. The reasons for push pull are even more so.
Hi Operahouse
Thank you for your comments
The input will be suppleid from a current source . The output is connected to a constant voltage load . The input /output voltage ratio of the isolator will be fixed ( 50% duty cycle + transformer ratio) .Therefore the input to the islator module will look like a constant voltage load to the circuit driving the input . If the input /output voltage ratio of the Isolator Module is 1 then the input voltage will adjust to be the same as the output voltage .Do you see any issues with this ?
Obviously, I do.
