NX 7.5 - object line thickness in view
I know if style, you can change the object lines to different thicknesses in each view.
What if there is a part that has many holes, and you want the border of the object to have thick object lines, and the holes to have thin object lines. Is that possible?
RE: NX 7.5 - object line thickness in view
I use View Dependent Editing to get what I want.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
If I were to take the time and pick just the holes, which icon in view dependent edit would I use?
I don't want to erase them? Or edit the entire object, just a line or two.
Select the circle object representing the hole and you can change the line thickness.
www.nxjournaling.com
Edit -> View -> View Dependent Editing
Go over the top four icons in the menu, and you should be able to figure it out.
Ask if you have more questions on it.
I am not sure where the toollbar icons are located.
