Basic bolt circle diameter dim. Does it control bolt pattern runout to a center?
I have a flat disk, 20 holes around, and see so many examples of bolt circle dia's dimensioned as basic with a position on the holes.
Does the basic bolt circle dimension control location to a center hole in the disk used as datum A?
Does the basic bolt circle diameter dimension still allow circular position tolerance zones or are they now constrained to arc shaped zones?
Thanks.
--mschroeder
Thanks.
--mschroeder
RE: Basic bolt circle diameter dim. Does it control bolt pattern runout to a center?
2) It does if you have a diameter symbol before the tolerance in your position call out.
Kind of hard to be more specific since you did not post a pic.
Thanks for the reply.
Side note: Currently the pattern of 20 holes is not tied in rotation to 3 arc-shaped holes in the center. If such relationship is required the print must specify this.
Powerhound, GDTP S-0731
Engineering Technician
Inventor 2013
Mastercam X6
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
First, we cannot see Detail view A which supposedly clarifies position of sausage-shaped slots.
Second, if position of slots is controlled by GD&T as well, vertical axis going thru upper sausage and horizontal axis tied to 11 deg. basic dimension have implied basic 90 deg. dimension between them.
I would be more worried about adding flat part surface as primary datum.
Inventor 2013
Mastercam X6
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
Well, you pretty much redrew the same scenario as in the OP. Was I supposed to see it any differently? :) Your depiction of what you call "real" is, in fact, implied if you go by YOUR interpretation of the fundamental rule. What would be "real" would be an angle from the hole at 90 degrees to the hole at 160 degrees. Believe me when I say I'm perfectly okay with extensions of principle when they are supported but I don't see where it's permissible to imply an angle from anything but a feature. Your 20 degree angle does not originate from a feature and neither does the 11 degree angle from the OP. Read the fundamental rules and see that in both cases (i and j) any 90 degree implication requires features.
Inventor 2013
Mastercam X6
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
As for implied basic 90 degrees angle between slots and holes -- sorry, but I do not see how this could apply here.
As for a need of planar primary datum feature, I fully agree - it is needed. However it does not necessarily have to be one of 2 flat surfaces of the part, but a center plane derived from part's thickness as well.
When I called the dimension “real” vs. “implied” I only meant that dimension actually is present on the drawing as opposed to the one we imagine to be there.
Para. 2.1.1.4 states in plain English:
“Where center lines and surfaces are depicted on 2D orthographic engineering drawings intersecting at right angles or parallel to each other and basic dimensions or geometric tolerances have been specified, implied 90 deg or 0 deg. basic angles are understood to apply.”
It does say ABSOLUTELY NOTHING about holes being associated with said center lines. So in my interpretation just center lines alone are good enough.
pmarc,
How about implied 0 deg. between top slot and vertical axis?
Just in case you guys are having problem with “intentionally incomplete” drawings, I am trying to show in finer detail how presence of properly toleranced slot will change the game.
Do you still believe that we must place basic 90 deg. dimension on the drawing, or is it somehow implied?
FYI the 11 degree dim to horizontal was there to tie three sets of smaller bolt circle patterns to each other rotationally and I neglected to omit it for my simplified image.
--mschroeder
You misquoted 2.1.1.3. Please re-post it without leaving out the functional word.
Inventor 2013
Mastercam X6
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
Inventor 2013
Mastercam X6
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
Powerhound,
First, it’s 2.1.1.4
Second, this is exactly how it looks in my copy of ASME Y14.5-2009
Third, when you are calling somebody a liar, it is your job to provide the evidence.
Inventor 2013
Mastercam X6
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
My problem with this entire thing is that the way the centerline is used does not depict a part feature. The only features a centerline depicts are an axis or centerplane. I've always related features to other features. Paragraph 2.1.1.4 is not in the 94 standard but 2.1.1.3 is, although it's actually 2.1.1.2 in that standard. Maybe the committee decided to give centerlines more power. I don't understand why though. You can't touch them to measure from them, you can only use features that establish them to measure from. Since in your "incomplete" and "more complete" drawings you have an upper feature to relate to, you're still not relating the hole in question to the 180 degree line, you still have to relate back to the feature at 90 degrees. I know you are just trying to illustrate a point but at what point does it become a better idea to relate a feature to something that can't be touched than to something that can? This is why I don't think that was the intent of the paragraph we are talking about. I'm sure if you were actually making that drawing for production, you would have related one feature to the other via a 70 degree basic angle.
Inventor 2013
Mastercam X6
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
Looks like it’s not the first example of Y14 making small adjustment that change the meaning greatly.
About centerlines – we still dimension to the center of the hole, right? Maybe things are not so bad.
I possibly over-reacted, but put yourself in my place – I quoted the sentence down to the letter, so I didn’t feel like I deserved such treatment.
Maybe I should use more care in the emoticons I choose. Is that why you took such offense? A simple smiley face probably would probably not have been so bad.
Inventor 2013
Mastercam X6
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
I forgot about emoticon already.
I totally agree that it is always better to give clear dimensions feature-to-feature.
But that’s the reason I was trying to convince you guys that implied 90 deg dimension is basic – there is no tolerance accumulation, so calculating 90-20=70 is “lesser evil”.
OP explained that his drawing was incomplete, so the whole argument was probably about nothing anyway. At least we figured out yet another difference between 1994 and 2009 editions.
