Laws with self intersecting sweeps
I created a guide curve and used it to sweep a surface with z-axis reference direction. Now, I want to use the guide curve to create a parallel curve using the sweep as the support and a Law (created from a sketch) to change the height of the curve. As long as the sweep/guide curve do not self intersect/corss over itself it works fine. Why won't the parallel curve work properly when the sweep self intersects? Is this just not possible? Is there a work around (maybe something other than parallel curve)?
RE: Laws with self intersecting sweeps
Rob Stupplebeen
https://sites.google.com/site/robertkstupplebeen/
http://files.engineering.com/getfile.aspx?folder=e...
Rob Stupplebeen
Rob Stupplebeen
http://excelspreadsheetshelp.blogspot.com - http://scripting4v5.com
