TOOL PATH CREATION FOR SINGLE PIECE IMPELLER
Hai,
I am using UG-NX-8,I completed the roughing operation by using CAVITY MILL with different tool axis vectors.for finishing the surfaces which option i have to use.i added image file for your reference.
with regards
T.Tanooj
RE: TOOL PATH CREATION FOR SINGLE PIECE IMPELLER
Try Surface Contour -Streamline using Interpolate to control the tool axis going around inside each cavity. I have in the past used a cylindrical sheet inside the cavities to use as drive.
Bill
