Basler power supply
Basler power supply
Basler power supply
Does anyone have an old (Prior to 1998) revision of the Basler BE1-51 book? I am trying to figure out what power supply voltage the letter "M" indicated before they revised the options to be "O,P,R,S,T". Why they don't print the power supply voltage on the relay is beyond me.
RE: Basler power supply
I looked at a Sept 1993 manual for the BE1-51 and it does not have an M power supply. It lists the power supply options as O P R S T. I guess your relay is event older then '93.
Andy
Their support is usually really good. I would give them a call.
Alan
I did and they did not help, didn't even seem to attempt to help which is odd because usually thier support is very good.
Well....I suspected you had already called them!
Alan
Found it if anyone cares, the "M" means "Current operated power supply".
