I-deas 6.1m2 on Windows 7 - Printing problem
I tried to instal I-deas 6.1m2 on Windows7 but impossible to print !
I configured all my printer with Print Administrator, and I also try to copy the old pm_server folder (from i-deas 5m3) in place of the new one.
When I go to the sdi print master website, I can't read it is available for Windows 7.
Does someone has a solution ?
Thanks, Romain
RE: I-deas 6.1m2 on Windows 7 - Printing problem
have you tried turning on the "windows print"?
Yes, the windows print works correctely but I need sdi print master for .tif export format for my drawing and I don't know how to do with windows print.
I have also a script to make automaticly an export tif with title block in french and english (I need both of them). And if I use windows print, i have to modify all that script.
Ok Cool We use a PDF Distiller with the SDI print and I think we tested this on windows 7 and could not get it to work. Are you running 64 bit or 32 bit windows 7? You may want to contact GTAC. Sorry for not being of any help.
We are running 64bits windows7.
I have contact GTAC but for the moment, no response.
Thank you anyway.
