Suppliers of 9-10GHz Voltage Controlled Oscillators (VCO)
Hi folks.
I am looking for a replacement VCO for one that has gone obsolete. I don't expect a drop-in replacement, so first off I thought I'd look for likely manufacturers. I'm not having much luck with the various search engines on the Web
but have found General Microwave, Sivers and SigTech so far. Perhaps our wide-ranging group may be able to suggest some other manufacturers I've not found yet?
Thanks in advance,
Brian
RE: Suppliers of 9-10GHz Voltage Controlled Oscillators (VCO)
www.modcoinc.com
Try the above site check the information on the "VS" series.
 Fill out the custom specifications form and submit it for a more specific response for your needs.
It's worth a shot.
