How to import a spreadsheet (NX6) excel 2003
Hi everybody,
If I edit a spreadsheet, a new window opens in excel, then I change the parameters. How can I import this parameters in my model?
Thank you
RE: How to import a spreadsheet (NX6) excel 2003
hi,
tools spreadsheet
add on
extract expression
make some changes in column B
update nx part
exit
yes to save the shheet inside the part
you can use the following function to read the value of expression "radius" for example in excel
=UGEXPR("radius")
I hope this help
Didier Psaltopoulos
http://www.psi-cad.com
