BS 1451-1 Area of application for B S-20 pipes
Hi Friends
We have Polypropylene pipe series S-20 B installed the pipe under the following conditions :
·Underground installation below the building slab and not outside the building.
·Depth from 400 mm to 1200 mm below the building
·The building slab is supported by plinth beams from around
·Fluid is condensate water from the AHU and FCU
we came to know that S-20 B can only be installed above ground , but given the fact that we have already installed we want to know what is the level of impact on the performance we are talking of? what is the severity we are talking off? what can be done or precaution that still can be taken off?
thanks for the help in advance!!!
