Pump Curve Operation
Can I expect to see shaft deflection for a standard centrifugal pump operating to the far right of the pump curve? If so, what would the mechanism for which the excessive radial forces would be generated? I would expect to see signs of clasical cavatitation as the NPSHr increases as flow increases but what about shaft deflection?
RE: Pump Curve Operation
"People will work for you with blood and sweat and tears if they work for what they believe in......" - Simon Sinek
