ANSYS Line Direction
I have been getting problems where I mass select lines and use LESIZE to apply NDIV and Spacing. However there is the occasional line that comes up with a reversed spacing. (ex. ---- --- -- - instead of - -- --- ----). I looked around online and I believe it to be due to line direction and can be solved with LREVERSE.
Does anyone know a way to set all lines to a certain direction or only select lines with a certain direction. Otherwise I would be forced to manually select the lines to reverse them and that is not an option for the model that I am building.
