Rerounding HDPE Pipe
Has anyone ever rerounded HDPE pipe after a vacuum collapse? I have a 4"/8" dual-contained HDPE force main. The 4" pipe collapsed, apparently after a vacuum release valve failure. I am exploring options to complete replacement of the pipe.
RE: Rerounding HDPE Pipe
Richard A. Cornelius, P.E.
WWW.amlinereast.com
“The beautiful thing about learning is that no one can take it away from you.”
---B.B. King
http://waterhammer.hopout.com.au/
Are you sure interior pipe is not e.g. instead "necked-down" as with pulling load, or alternatively has leaked and leakage is exerting/has exerted excessive external pressure in the interstice between the casing and carrier, and thus against the outside of the 4" pipe?
