whipped topping
whipped topping
RE: whipped topping
forgot to say, nx8.03
sorry new in NX
regards
Erwin
RE: whipped topping
Do you want help on how to to design a similar shape or is this something i don't understand ?
In case you really want to design a similar shape, the difficulty is the irregularity, i.e it is a simple task to design a sweep along a "helical" spline, but then make it irregular is probably more a task for the X-form command and some time spent.
Tomas
RE: whipped topping
I want to design the shape not the air winky smile
I have played around with cone reworked with x-form. I'm not happy with result.
sorry new in NX
regards
Erwin
RE: whipped topping
What you need to do is take place whipped topping on a plate like it's shown in your picture, have it digitally scanned, and then download that scan into NX. :)
RE: whipped topping
its not that hard of a model to create i cant do it at work but if i remember when i get home tonight i can whip it out. Sketch the outer profiles and connect with surfaces i have examples at home that i will upload to give you ideas
Ryan Lee
Design Engineer
If you can think it it can be modeled
RE: whipped topping
"when I get home I can whip it out"? You're killing me on a few different levels, but I'll just chuckle at the whip cream pun.
RE: whipped topping
Friday chuckles were implied
Ryan Lee
Design Engineer
