problems dimensions catia drafting
i have a problem with the value when i dimension in catia drafting, the position of my value is above the dimension line? is there
any way to make it in the middle? because i've seen some video the value was in the middle
thank you
RE: problems dimensions catia drafting
Change the drafting standard.
ISO, DIN, and JSI standards place the value above the dimension line.
ANSI and ASME place the value in the center of the dimension line.
thank you so much
how can i add a symbols for ex: diameter symbol or countersunk symbol in catia drafting?
Hello zouz555,
To add any (common) symbol in front of a dimension, you need to select it first with a click and then select your symbol you desire.
Hope this helps.
Best of luck!
CATIA V5 R21 – mold tool design engineer
plastics industry
