Heat Transfer ? - Steel Tube/Duct
Duct is a 8” x 8” steel square tube with 0.3125” wall thickness, 200” long.
Duct weight 742 lbs.
One end is capped off and the other end is capped off except it has a 4" OD inlet opening.
An external heat source will be used to pump heated air through 4" OD opening in the tube.
The duct is placed in -40 degrees F outside still air.
Determine overall BTu's per hour to heat the steel from inside to out to bring the outer surface from the -40 to 32F
Determine the required forced air temperature of heat source on inside of duct to maintain outer surface at 32F
RE: Heat Transfer ? - Steel Tube/Duct
B.E.
The good engineer does not need to memorize every formula; he just needs to know where he can find them when he needs them. Old professor
B.E.
http://www.roymech.co.uk/Related/Thermos/Thermos_H...
I'm assuming that since you've been here a while, you'd have to be a super-senior times 3 to still be a student, yet your problem statement is couched precisely the way homework problems would be formulated.
TTFN
