Etabs model attached , need help in detecting the problem in it.
Whats wrong with the attached file?? see the period of mode 1, it is not realistic. there is a problem with the slab but I cannot solve it. Any help??
RE: Etabs model attached , need help in detecting the problem in it.
Analysis and Design of arbitrary cross sections
Reinforcement design to all major codes
Moment Curvature analysis
http://www.engissol.com/cross-section-analysis-des...
then assign the dead load on slab based on SIDL case. Hope that helps.
