steel tank on concrete differential expansion
hi we have a steel tank being placed on a concrete foundation slab which is piled. how do you account for any differential movement due to temperature if at all. tank is not fixed to concrete by any bolting
RE: steel tank on concrete differential expansion
If the tank is not fixed to the foundation, why are you worried?
Also, this must be a shallow wide tank for no bolting considering wind and seismic.
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
Differential movement is not usually a consideration.
