Taper in shell area
Taper in shell area
I am Baiju(Static equipment engineer), Kindly go through the query and help me with valuable suggestion.
In our case a shell is coming with 1:3 taper, kindly let me know that whether we need to check the hydrostatic stress over that area. If it is overstressed then what is the solution to get out of this. Nominal thk. Of shell is 100 mm and taper end thk is 90mm. Applicable code ASME sec VIII div 2.
THANKS FOR YOUR CONSIDERATION AND SUPPORT IN ADVANCE.
Baiju Eapen
Static Equipment Design Engineer
RE: Taper in shell area
Baiju Eapen
