Help needed, Reciprocating compresso
Reciprocating compressor, three stages, one piston balance, driver: steam turbine, gearbox BHS 20/1, couplings: metastream( flexible),
We have started turbine+gearbox without any problem, the compressor without gearbox and turbine(with barring) has started without any problems also, but when gearbox is coupled to compressor in both cases of barring and turbine, we observe a hard vibration and high noise over "low speed shaft" which shutdowns the compressor, what is the reason?
RE: Help needed, Reciprocating compresso
I would remove a couple valve cages or a cylinder head and inspect internally.
Check for liquid. Check your rider bands and piston rings.
What is the history of the equipment?
What is the process?
too much information needed.
During Precommisioning of compressor we don't see any vibration on turbine and compressor, turbine alone and with gearbox had a good result on related tests, but when gearbox is coupled to turbine and we increase the speed of turbine, we observe an unormal vibration and noise which are increasing in amount over low speed shaft that make a shutdown immediately.
Sincerely,
Torsional vibration is usually a silent killer and not generally detectable with normal vibration equipment, but since you have a gear box with allowed a modicum amount of torsional play available, it may be manifesting itself as gear noise and shaft vibration.
