Streamlines
Streamlines
Has anyone ever used an old DOS program called, "STREAMLINES"? It is for piping networks. Seems pretty powerful, but is clumsy to use with Windows. Would like to hear from any users on tips to make it easier.
RE: Streamlines
Isn't Google amazing?
Good luck,
Latexman
RE: Streamlines
Works fine once you get the hang of it.
Results seem credible.
Mike Halloran
Pembroke Pines, FL, USA
RE: Streamlines
Mike, how do you get to the DOS window in XP? My computer does not have such prompt. I have to use it with wordpad and it is tricky. Getting better at it though. Hardest part is inputting data in right place. Have to put the txt files in STREAMLINES folder too.
RE: Streamlines
or Start|Run|Command.com
or, better, write a batch file (they have a different name under XP, but I'm old)
to cd /STREAMLINES
and do all the other housekeeping.
Actually, I think such a file comes with the program archive; you just customize it and set up a shortcut to it.
Above may be inaccurate; my XP machine is busy/crashing trying an iPhone upgrade.
I mostly use Fedora Linux now. ... and haven't found a way to run Streamlines in it.
Mike Halloran
RE: Streamlines
RE: Streamlines
But be aware; I remember having difficulty with a very similar issue, and I'm not recalling exactly how I dealt with it.
Mike Halloran
