Material for Sodium Hypochlorite
For one of the Offshore project NORSOK standard has to be followed. For handling Sodium Hypochlorite injection system, as per the standard, we have to use Titanium or GRP. For the Injection pumps hence , we have to necessarily use Titanium material which are highly costly. Is there any other alternative for this material ?
RE: Material for Sodium Hypochlorite
If a magnetic drive pump is used, a power monitor must be used to prevent dry running of the pump and damage to the shaft and bearings. There are many choices of diaphragm pumps for small flow applications. Many choices for the pump housings
are available and successful. The diaphragms can be of Teflon® or some rubber compounds. However, if rubber
compounds are used, Viton® is the preferred choice. EPDM is successful but may not have as long as service life as
Viton®.
Rgds
I have see Ti housings and plastic impellers used together in this service.
Plymouth Tube
