Acoustical Panels
Acoustical Panels
Say if I have a 8" fully grouted CMU wall. Normal STC Rating of roughly 55. We are to install acoustical Sound panels perfm. metal with a 23% opening and with a 2 inches thick, 2.5 pcf density fiberglass sound absorber encased in 2 mil thick, black, PVC embossed vinyl that has a 90% NRC.
Now do you add the STC rating of the panels to the wall or do you consider only the higher value.
IE
Wall=STC-55
Panels=STC-35
STC rating= 95?
or STC Rating STC-55
IE
Wall=STC-55
Panels=STC-35
STC rating= 95?
RE: Acoustical Panels
If you decide to leave it over here, realize that not everyone here is in your discipline. You will get a better response if you don't use "TLA's" (or three letter acronyns) of which I counted five in your post. One tripped me up, because the meaning that I would normally assign to it (NRC= Nuclear Regulatory Commission) makes no sense in terms of your post. People might have cross-discipline experience that would apply but not realize it because they are not familiar with the particular accronyms you are using. Therefore please consider defining your accronyms.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
Cheers
Greg Locock
http://www.eng-tips.com/threadminder.cfm?pid=384
And spell out your acronyms.
