Drafting Dimensions
Drafting Dimensions
Drafting Dimensions
Hello, I am new on drafting. How do you display the dimensions to show the unit in inch/mm? I want both US and metric units to appear. Thank you.
RE: Drafting Dimensions
Hi.
I don't think that both,US and metric units,can be displayed at the same time.If you want to change the unit dimensions(Ex:From US to metric)access Tools/Options/General/Parameters and Measure/Units.
Go to the Properties Page of the dimension - The Value tab has the Dual Value options you are looking for.
Win XP64
R20/21, 3DVIA Composer 2012, ST R20
Dell T7400 16GB Ram
Quadro FX 4800 - 1.5GB
DBezaire,
"Dual Value options" does not show both inch/mm.........!
mz7dyj,
You are absolutely correct. It shows more than just inch/mm, it will display 15 different configurations/value. So you could get feet, km, micron, cm,...
It just so happens that my example pic will show you NUM.DINC (inch) and NUM.DIMM (mm)
Win XP64
Dell T7400 16GB Ram
Thanks to all, it helped out.
