Concrete Column Repair
What is the best way to repair the concrete column in the photo.
The building age is around 45 years old
RE: Concrete Column Repair
Take the pen out of the crack.
Figure out why the column failed. It looks like a patch to the column failed. Why did it fail in the first place?
Knock out the column.
Build in a new better column.
Take out the shores.
Can i use ordinary concrete or it is necessarily to use micro-concrete?
Thanks JC for your quick reply
Dik
Analysis and Design of arbitrary cross sections
Reinforcement design to all major codes
Moment Curvature analysis
http://www.engissol.com/cross-section-analysis-des...
