Metal Expansion Joint use via ASME B31.1
Trying to determine if the use of an expansion joint is acceptable based on configuration and ASME B31.1. It would be beneficial in reducing thermal expansion problems. I have parallel firetube paths feeding a steam drum. I would like to know if I can put the expansion joints on the inlet and outlet sides of the steam drum on the firetube paths or if that is not accepted. My guidance I have thus far is from 101.7.2 which states "However, flexible metal hose assemblies, and expansion joints of the corrugated bellows, slip or sleeve type shall not be used in any piping system connecting the boiler and the first stop valve in that system.
Appreciate any assistance with this.
RE: Metal Expansion Joint use via ASME B31.1
rmw
Thanks for your time and input. I do read this as a non-allowance of the ej in that area though.
The following restriction has been removed in Edition 2012 of B31.1 because para. 101.7.2 has been revised, its last sentence has been deleted.
"However, flexible metal hose assemblies, and expansion joints of the corrugated bellows, slip or sleeve type shall not be used in any piping system connecting the boiler and the first stop valve in that system."
Nasir
Welding Engineer
DESCON ENGINEERING LIMITED
PAKISTAN
The above sentence has been removed from 101.7.2 but has been added in the form of a new sub-paragraph 122.1.1(I) that is more logical to put it under master para. 122.1 that is design requirements pertaining to BEP.
Sorry for my statement in my very last comment. Now I have same opinion as Metengr has.
Nasir
Welding Engineer
PAKISTAN
