A706 Gr60 rebar welded to P8 stainless steel plate
What tests are required to qualify a PQR for welding A706 Gr60 reinforcing bars to a P8 stainless steel plate to be used as an embed in concrete. All welding will be performed in the flat position.
RE: A706 Gr60 rebar welded to P8 stainless steel plate
This typically falls under the jurisdiction of AWS D1.4. It will outline the required qualifications based on joint geometry and a number of other variables.
