Assembly sequence to arrangement
I had a question ( dream) / may I don't know:
can I put an assembly sequence (the end status) into an arrangement?
RE: Assembly sequence to arrangement
Tools -> Capture Arrangement...
...and assign a name to the new Arrangement.
Now after leaving the Sequence task, you can simply select the new Arrangement and you Assembly will move to match that saved Sequence position.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
is there a trick how to handle existing assembly constraint,
deactivating inside sequenzing works, my captured arrangement doeasn't work outside sequencing
regards
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
played a little bit around,thought about further discussed explosions, but no trace lines in sequencing, sequence views doesn't work on drawing sheet (nx8). What are the future plans with sequencing?
thx
And yes, there are no automatic 'trace lines' in Sequencing since, as I've implied, it's not considered an atualy 'Exploded View' tool, despite the fact that you can sort of fake it. As for the issue of 'Sequence Views' not working on a Master Model Drawing, yes, they have the same limitations as do 'Exploded Views' today (and this issue has NOT changed in NX 8.5).
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
