Properties box
Properties box
Properties box
Hello! I am new to Draftsight. I have been studying the lessons and have run into a problem. I am not sure if this forum is where I should be asking this question. If it is inappropriate I am sorry. But, here goes. In Lesson 3 at nearly the end, it says to scroll to the "Tolerance section" in the "Properties manager palette". I have searched the palette thoroughly and cannot locate a Tolerance section. Any advice on what is wrong? Thanks!
RE: Properties box
Did you have a dimension selected when searching the Properties Manager?
The Tolerance section is near the bottom of the manager.
