Specific heat of water relation to water's Total disolved solids (Conductivity)
thread481-148741: jet fuel specific heat vs. density -- correlation?
What is the Relation between the specific heat of water and the water content of TDS (conductivity)
RE: Specific heat of water relation to water's Total disolved solids (Conductivity)
we need to know how will the speciifc heat of the cooling water be affected by changing it's concentration of TDS (total disolved solids)?
Are you saying that is because of the cycle-up of TDS (and non-dissolved solids) in the water, or the result of them being there by virtue of the fouling they cause on heat transfer surfaces in the cooling equipment.
Husam...
If you take pure water and mix salt in it thereby driving up the TDS and the conductivity, you have virtually no effect on the heat capacity of the water. IF on the other hand, you dissolve enough of a substance in the water - think sugar - and drive up the TDS you have a different solution, a syrup solution and it is not basically water any more.
rmw
