Move component CSYS to CSYS problem
Hello, i have problem with moving component by method CSYS to CSYS.
Can not be selected any geometry in assembly. See image.
I have latest MR 8.0.3.
NX 8.0.3.4
RE: Move component CSYS to CSYS problem
where you see the box in your image where it says within work part only, change this to entire assembly
hope this helps
Best regards
Simon NX7.5.4.4 MP5 - TC 8 www.jcb.com
On you image, can you see the box which says within work part only? well change this to entire assembly
Cheers
Si
Best regards
