Who accepts final responsability for a drawing; the Certified Drafter or the Engineer that checks it
This is a question that has plagued me for years and I've been on both sides of the fence with it. I originally started out as an Industrial drafter (AS Degreee) and worked as a drafter/designer. Then I went back to school and got a BS in Mechanical Engineering.
My question is: When a drawing is produced by a certified drafter and then it goes to an Engineer who checks the drawing. If the drawing has mistakes and it makes its way to production and leads to an accident, who will be responsible? The drafter or the engineer?
I feel as if the mistake was on the drafting portion (as in an incorrectly applied dimension/tolerance/GDT.etc) than it is the drafters fault. After all, very little is taught on ANSI drafting standards in Mechanical Engineering School so how can we expect the engineers to catch this?
However, if it is a mistake in the engineering/design of the part but the drawing was correct than it is the engineers fault.
Does anyone have any official answers or cases they can reference? Up to now, all I've ever heard was opinion on this topic... But if the Sh*t ever hits the fan, how will it really play out in the legal system? Who is responsible?
I've had engineers who felt they were responsible for the whole drawing & everything on it once they sign it; and as a result they would sometimes spend HOURS checking it (sometimes longer than I had spent making the drawing!). I would understand this notion if it were actually true that the engineer is totally responsible after checking & signing it... But this seems illogical... I've seen some engineers (who were not trained in drafting as I am) make some pretty pathetic drawings... So how can they be expected to be responsible for the drafting portion of which they know little about?
Feel free to give your opinion. I'm hoping someone who has "been there done that" or a lawyer will post some facts and put this question to rest once and for all.
VS
VS
RE: Who accepts final responsability for a drawing; the Certified Drafter or the Engineer that checks it
If in the world of PE's (in the US) where the engineer actually has to stamp the drawing etc. then I believe the legal buck falls to the PE.
In the exempt world then as I understand it the company is primarily legally liable.
Who the company blames is up to them.
The typical saying is the last person to sign it takes the blame or similar but that's a bit harsh!
As for "After all, very little is taught on ANSI drafting standards in Mechanical Engineering School so how can we expect the engineers to catch this" well frankly if your job duties require it then you need to learn it, or find another job. Plus, if you're so good at drafting surely you know they're ASME standards now in the US
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Every company I have worked at, whoever signs the drawing is responsible for its content.
The "drafter" usually makes the drawing based in info supplied by the designer and/or engineer.
Chris
SolidWorks 11
ctopher's home
SolidWorks Legion
I would think that first of all it is a responsibility of a company that prepared poor documentation and/or poor product based on the documentation (even if the print was perfectly according to all standards required), and not of a single man in particular - assuming that the single man is not a drafter, PE, drawing checker, manufacturing engineer, quality engineer, inspector etc. in one.
In my previous job there were at least 4 signatures required on a print: drafter's, PE's, tooling engineer's and so-called standard checker's. All of the signatures were equally important, because involvement and expertise of all the persons were absolutely required in the process of releasing a part for production. So each of them were partially responsible for the print, but in case of any product issues in front of customer everything was company's fault. (Of course internally the company could blame all of people signed on the print or none of them. All depended on the situation).
But the way I see it, both engineer and drafter are merely hired help. They are “following orders” (read with German accent).
Another reason company shouldn’t point the finger at the employees is that, should the case go to court, you really don’t want your drafter who has nothing to lose to testify under oath about inner workings of your joint.
Cynical? Well, I am old and tired.
Like ctopher, I have never heard of a certified drafter. A lot of drafters these days are CAD operators, with minimal expertise in drafting.
In any case, GD&T is a language. If you do not understand the language, you don't understand the drawings, and you have no business signing them off.
I asked this in the Ethics Forum, thread765-194599: Drawing Checker/Approver Qualifications.
JHG
Matt Lorono, CSWP
Product Definition Specialist, DS SolidWorks Corp
Personal sites:
Lorono's SolidWorks Resources & SolidWorks Legion
I feel the responsibilty lies with the checker.
When a drawing is sent for checking it should be checked not only for functionality but that it fits together and therefore the checker should carry out a tolerance stack on the relative components before signing off as okay.
I find this link gives a list of things required for checking drawings:-
http://roymechx.co.uk/Useful_Tables/Drawing/Checki...
Matt Lorono, CSWP
Personal sites:
If the checker is a senior person with authority over the designer, and they are given adequate time to completely review every single document in the design package, then they can be held responsible.
I would hold the designer responsible. The checker's job would be to catch enough mistakes to justify the time and effort required to do the design checking.
JHG
So, the checkers job is to justify his own existence while not being actually responsible for anything?
Checkers…
SW Premium 2011
64 bit SP4.0
Intel Xenon X5650 @2.67GHz
2.66 GHz 11.9 GB of RAM
Let's try to construct a functional engineering and design office.
The designer sits at a CAD station designing something. Possibly, and engineer is looking over the shoulder of a CAD operator, but I don't think this is functional. CAD is user friendly. It is not like back in the days of drafting boards, and people with good line-work and lettering.
When job is complete, the drawings are checked by someone. In many organizations, the checker is juniour, and the company lacks standards, so all the checker is looking at is dimensions and spelling, if he knows what is good for him. We cannot hold him responsible for design errors.
In a saner environment, the checker is an experienced designer with good overall knowledge. The designers and projects managers respect him. Still, there can be a conflict. If this is hard to resolve, I am in favour of the designer taking responsibility, and sending the drawings out without the checked signature. He is putting his ass on the line, obviously.
There has to be some sort of organization underlying the person responsible for decisions. If the design checker is doubling as the coffee boy, he cannot be held responsible for anything, other than spilling coffee.
JHG
This is why I believe “checker” should be assignment rather than profession.
CAD is easy, you said it yourself.
So, instead of engineer/designer/detailer/checker chain why not to have engineer A assigned to check work of engineer B and vise versa.
In larger groups you can even have setup similar to what pmarc described in his post from 9/20:
Engineer with better knowledge of manufacturing could do feasibility check and engineer with better knowledge of standards could check the compliance, and sign the drawings respectively.
All of them still able to do something productive rather than justify number of red mark-ups.
How’s that for “functional engineering and design office”?
That initial, or signature, is responsible for that design interpreted on the drawing.
Chris
SolidWorks 11
ctopher's home
SolidWorks Legion
Titles mean nothing. Names of boxes on prints mean less. In exempt industry, companies are responsible to the public (vendors, bystanders, and customers), end of story.
As far as responsibility within the company, that is determined by the company's policies and procedures and the people charged with carrying them out. A name on a certificate or degree does not change this.
I'll try to summarize what we are taught about law in our field. In Ontario, Canada it is up to the engineer who signs the drawing to accept responsibilty. He may have others detail but it is his duty to ensure that the drawings are checked. In the unfortunate event where there is a breach of duty, where that duty was owed, and damages are present then it is up to the courts to decide on how much liability ($) both the engineer and the company that employeed the engineer owe the damaged party. If there is more than one to blame than the courts would look at concurrent tortfeasor to share the damages. This would fall under tort law, which I believe is similar to those in the States. But check with your juridiction to be sure.
The textbook where I got this from...
http://www.amazon.ca/Law-Professional-Engineers-Do...
John-Paul Belanger
Geometric Learning Systems
http://www.gdtseminars.com
You are assuming that engineer who signed off on the drawings has continuing control over them. In lots of organizations, someone will demand a change, and supervise a low level drafter as they make the change. The engineer will find out about all this, later.
JHG
in the mechanical engineering world I live in, PE's are about as common as honest politicians... So to summarize it all, this is what I'm getting; In your typical company, the engineers are protected by the corporation they work for. So when the "fecal matter is on a collision trajectory with the rotary oscillator", it is the company for which the engineer works that will take the fall. And then the company can distribute blame & disciplinary action however they see fit (up to and including termination).
But this does nothing to ease the engineers who want to spend more time checking the drawings than it took the drafters to drawing them -- to the extent that they would rather let someone who is ill qualified do the checking & sign the "check box" than have to check it themselves within a reasonable amount of time & sign the "check box" themselves... Perhaps pride plays a role in this quagmire...
VS
The company with the logo on the lower left of the print.
We have drawings with 6 signatures on 'em - and not one of those six people are with the company anymore.
JK
All companies I have worked at, it's on the lower right.
Chris
SolidWorks 11
ctopher's home
SolidWorks Legion
I must have been thinking I was in the lower hemisphere !!!
JK
