Is there a way to Group multiple components/(parts) in an assembly, and pattern that GROUP ?
Hi all,
In CATIA v5, Is there a way to Group multiple components/(parts) in an assembly (Product), and then pattern that GROUP ? I've been trying to do it for 2 hours now, and I can't figure it out. First, I tried to group the parts using
DMU Navigator > DMU Review Creation > Group "button"
then used the Define Multi Instantiation command... It didn't work. It wouldn't let me select the "DMU Group" ...
Is there another way to do it?
- Thank you
RE: Is there a way to Group multiple components/(parts) in an assembly, and pattern that GROUP ?
CATIA V5 R20
PC-DMIS 2011 MR1
then get your parts inside that component--think of it as a folder in your product tree for your parts--notice there is no background sheet behind the "component" icon, compared to one for an assembly or a part. now you can reuse a pattern from one of your other files...
regards,
LWolf
If you go through the extra work to create a separate product file and add in all of the components, constrain them appropriately, etc., then you have something that can be added to this assembly and any other assembly in the future. It just depends on how much time you want to invest in future reuse.
CATIA V5 R20
PC-DMIS 2011 MR1
Thank you all for your replies. I appreciate the feedback...
